janschutz
Corn Hauler
When at a stop light, car in gear, and the AC on, the the 351W is stumbling and sometimes dies. If I turn off the AC or put the the C4 transmission in Neutral, the engine then run smooth. I have checked the coil and alternator and timing. which are fine.
The alternator is a 65 amp, is that too low? What else to check. Someone at the local car gathering said I should go with a high amp 1 wire alternator. Looking for input please
