Dyno Tuesday
copasspupil
Taking the car to get dyno'd and the once over before Spring hits. Can't wait. Any guesses? Engine 347 scat strip with paxton supercharger and afr 185 heads. 9" with 3.89 trac loc. Mustang dyno is being used.
What kind of cam are you using? How much boost are you running? Injected or carb? I have a Vortech blower, fuel injected, 12lb of boost and 333 ci.. Mine put down 555 at the wheels but I am also using H2O/Meth as an intercooler. My old engine was a 306, Ford E cam and AFR 165 heads and had 404 at the wheels. I will guess 480.
Blow thru demon carb, custom grind cam heads are 2.02/1.60. Computer dyno said somewhere around 617flywheel/589 tq. doubt I'll be that close
Apparently I need a different ignition box. My digital 6 won't work as well as the msd6462 blower specific model. If I cannot locate one and get it delivered there on Tuesday. Ill have to do it another day
The mechanic found issues with my carb being dirty especially this very fine rust like stuff. The fuel filter I have filters to 8 microns.
