Get me horny
KBMWRS
sad
:roll
So I'm not horny (now there's a set up for you guys).
I took the LeCarra wheel off and the contacts make a spark(occassionally) but no horny sounds.
Walk me through what to check next. :roll
If you jump the two horn contacts the horn should sound. If not, you may have blown the fuse when you were removing the wheel. Probably a good idea to disconnect the battery before you mess with the electrical stuff on a car.
Are the hornies OK ? :stu
Did you test them? :hide
maybe one hornie is bad and drawns too much current . :confu :confu
Up until 1970, horns got their power from the headlight switch and not the fuse box.
And if you want horny, how about this:
