68stang289
I'm finally at the point where the car is up and running and I'm just working on dialing in and finalizing a lot of small things. When I got the car, the springs were original and pretty worn so I picked up a new set. I expected that they would settle a little and that the front end would lower a little as a result, but the car has not settled very much at all. I have attached a few pictures that I have at the moment that show that the car is sitting pretty high.
I was thinking of running a drop spring because I really need to bring the front end down, but have exactly zero experience with suspension. The car is only going to be driven once or twice a week, with the occasional trip to my local drag strip. My setup is KYB GR-2's with stock everything else and running a 15" rim up front (if that makes any difference). I'm looking at maybe a 550#, 600# or 620# spring to replace. Anyone have any experience with the three different springs? Any rubbing issues? Will there be any noticeable difference in ride quality between the 550, 600 and 620's, or are they all going to deliver the same pretty stiff ride?
