Daves69Coupe
I think the shaft pulled up a lil when I pulled my dizzy. Its not all the way out, but I think it moved up cause my dizzy won't go back in all the way.
"AzPete" said:It should have a clip to keep it in place. If the gear teeth are engaged, turn the engine by hand while keeping gentile pressure down on the dist. That will allow the shaft and the end of the dist to align properly and the dist should drop down.
