PCV valve grommit
Dave2g
I had to do a temp fix for mine, has electric tape around the PCV Valve so it fits in the grommit..
Does anyone know the stand size for a 67? I have seen 1.22 or 1.25. I'm buying both the grommit and valve (elbow)
289. it could be a 1.25 and the pcv be a 1.22. But there has been a lot of work done on it 15+ years back so it could be any size
Just to clarify, I assume this is the grommet in the valve cover and you then have the valve attached to it?
I had to go back and look at the Turd's setup which is a basic valve cover filler cap with a hose snout. Hose then heads towards the carb with and inline PCV Valve in the hose between the valve cover and carb.
Fram's FV112 inline PCV valve. The largest OD is just .750, so I can't help you on a valve cover PCV Valve.
Tapayakin' from my iphone
The two different grommets below are from Summit Racing. Here's a link:
http://www.summitracing.com/parts/fms-m-6892-f
The grommet on the left has an ID of .75 to fit the PCV Valve next to it. The grommet on the right has an ID of 1.0 to fit the breather cap. Both grommet's have an OD of 1.22.
