stang32
i just blasted my frame after removing the entire floor now i need to protect it. what should I use?
I have etching & epoxy primers but I am out of rust encapsolator. I have it on order along with Internal Frame Coating from eastwoods.
there is flash rust starting in some areas & forecast calls for rain.
I do not want to do this job over again so what should I use or should I look into
picking up something local like from home depot or other local atores. if the epoxy & etching primer are not recommended?
