Wheel hub/bearings
My 07 is lowered which causes it to have negative camber. About 3 degrees. This is wearing out my tires of course. It’s not horrible but they are wearing uneven. Anyway I had a vibration so I bought new wheel hub/bearings. They are Ford Performance. The wheel studs are really long. They are ARP studs. Is this a racing thing? Why do they need to be so long? And what lug nuts should I use?
We don't do them OE for Ford (whew!).... it ain't Timken...... must be SKF.
Hard to believe you had problems; their stuff (bearings & hubs) = pretty good product.
Ford Racing doesn't buy hubs from us; the only other people that are likely is...... you guessed
it..... SKF.
ARP studs are a "race" deal. You only need the original length if you have original wheels on
your Mustang. The extra length is so that threads VISIBLY protrude on the outside of the wheel nut
(It's a requirement in most race sanctioning bodies' rule books).
Wheel lugs are the correct diameter/thread and seat that matches your rim design.
Isn't there an aftermarket camber/caster kit available that will let you get the right ft end alignment numbers?
I didn't have problems, I just didn't realize when I ordered them that the studs were longer. The description said it had ARP studs and did say they were 3" but I didn't pay attention to that. I'm okay with them being longer and I figured there was some reason like the rules for a sanctioning body. I have 07 Shelby GT500 wheels on it, nothing special. I am also going to get the camber/caster plates so I can align the front-end. I didn't check the alignment when I put the lowering springs on but after noticing the tread wear I took it in. They said there wasn't enough adjustment with the stock set-up. I ordered some BBK caster/camber plates from Summit. I just bought some regular lug nuts for now so I could put it back together but I'd like some chrome ones since you can see them. It handles great but tires are too expensive to chew up just the inside tread!
Make sure you compare/check the lugnuts you ordered against the stock ones. I know 94-04 use what's refered to as a Bulge acorn style lugnut.
I ordered the ones recommended by the paperwork with the hubs. It’s Ford performance part number. Thanks
The unit you have there in the photo is the hub carrier. Mine are fine. The hub carrier is what holds the bearings it's the axel hub that I'm after that the driveshaft slides through and it slides into the bearing.
Right ! This is very important.
The wheelnut has to be matched with the rim !
I often see that people , when switching to winter wheels (tires/rims) , they take the same nuts but the rims are aftermarket and don't always have the correct pattern.
And if the center hole of the rim is larger then the hub , all forces comes to the studs and nuts , which isn't right !!
The center hole of the rim must matches the hub , or with the use of center rings. But they have to match the rim perfectly !!
Something overlooked frequently IMHO .
I have missed something, are you looking for parts of do you have a question?
