P.S vs Non P.S Idler arm, what is the difference?
midpack
The vert needs a new Idler arm, failed vehicle inspection :dun
I've been looking for one and some suppliers list them together, some separate..
What do I need to look for?
BTW... the car is power steering
Napa has them if you not looking for concourse. If you have OEM you may just need a bushing
Manual Steering have a rubber bushing which twists during turning and is meant to snap back the steering wheel after turning... power steering doesn't have this feature...
and if you get rid of the pos rubber twister and use a roller bearing with 2+ degrees of positive caster, it'll do the same thing with less effort!
I think this is reversed: it is the power steering idler arm bushing that has the serrations to allow the system to return to center.
