March's COTM header pic
BTW how is the sitution with the fastback Mike ?
We need update and of course PICS !!!
Don't worry Mikey, keep driving it till it spits the lifter out and then the noise will go away!
Still in my garage.
And I heeded the advice of Opentracker.....
no driving it till it breaks for me. :steer
"KBMWRS" said:
Still in my garage.
Serious time, have you pulled a valvecover to see if any rockers are loose or studs have pulled out? Did it pop thru either the carb or exhaust?
I would've had the valve covers off before the tow truck arrived. I couldn't sleep till I found the problem.
UPDATE
So here's the outcome....per mechanic
It was the rocker arm adjusting screw like Jeff noted happened to me before. These are stock screws which have jam threads which have a propensity to back off over time. The recommended torque for these is only 3lbs and a few others were easily moved by hand so a fix was needed. Finding stock screws was also a challenge so the next best thing is a upgraded adjustment screw with a lock nut designed with it from Crane Cams. This did necessitate tapping the rocker arm hole to acccept a full threaded screw. Of course all the rockers were upgraded so this won't happen again.
All is well now and the '67 is back to normal with an abnormal driver. :steer
http://www.cranecams.com/322.pdf
Maybe it's me, but the angle of the pushrod and rocker looks HUGE.
Oh Mark, You're sniffin too much tractor fumes............Hey wait (rubbing me eyes)! Maybe you're right.
